Old 06-11-2012, 09:53 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
For the reverse lights, you will use connectors A, B, and C (B is the same connector as above). You should have A and B on the new wiring harness, connector C is on your transmission. You will want to run 2 wires, one from connector A pin 5 to connector C pin 1, and the other wire from connector B pin 1 to connector C pin 2. It actually doesn't matter which wire goes to which pin on the transmission connector (C) as its just a open/close switch.
Hopefully all that makes sense lol
