Old 06-10-2012, 11:50 PM   #11
Ranma
Ranma's Avatar
Originally Posted by akue View Post
I haven't really looked I've pretty much glanced but as I was taking the postive off the car had got power but the kept cutting back out soo I'm guessing a ground came undone?
Check the main ground. Don't glance at it take it off and do a proper inspection. It makes sense, a bump and a corroded cable breaks.
It is the main one from the battery to the frame. Mine has a ground right to the frame. Did you try a volt check from the positive to the frame?
