Old 05-26-2012, 01:50 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
JDM engines have all the ports for EGR, you just have to remove the block off plates and swap your parts over (including the cooler). The easiest way I can think of to make sure you do everything right is to pull the engine, put the 2 engines side by side, and swap over everything that's different. Depending on year, you may have to swap oil pans and oil pump pickup tube/screen. Since you have a Cali car, you will have more emissions components and electronics. Be sure you get them all so you can pass that wonderful smog test
