Old 10-15-2005, 11:49 PM   #2
hangsupra
i not sure bout the mk3 but my mk2. when it happen like that on me... i check it... n the proble i found is the radiater cap... i replace with the new one n it works fine..... oh by the way. check on your radiater cap.. second check on the radiater to see if there is any leak... third... check on your water pump... sometime it does that too... one more thing... if your car is a turbo then sometime the turbo is causing too... double check on it... start the car n look at the back see if there is any smoke... coming out from the exhaust... that what happen to my mk2 turbo tho... n i rebuild my turbo n after i rebuild my turbo its fine to... so check on that to... n double check on all your water hosing to see if there is any water leak alright. hope this work. let mek now how you get to work alright.
