Old 05-15-2012, 11:06 PM   #25
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by fastsupra View Post
Yepp thats the kit I'm running and I will be running Boost Juice.
So Would 25lbs be out of the question? Why should I add those to my tank?
25psi may be possible but I wouldn't start there. I'd suggest starting your tuning process at 15psi, be sure your methanol is spraying, and go up from there one or two psi at a time while checking your knock sensors on each run. You should also tie the methanol kit's low-level sensor in the methanol tank into your ecu/piggyback/etc. if possible - to (for example) auto limit boost or auto retard timing when the methanol runs out.
The upper cylinder lubes are to help protect the injectors and upper cylinder/head components from the potentially harsh/corrosive effects of methanol.
Life begins at 30psi.
