Old 05-07-2012, 07:33 PM   #21
btwilson86
Super Moderator
btwilson86's Avatar
After much research (you're welcome) I have concluded that on a 92 Supra Turbo, you're wiring is correct:
Blue - Red
Red - Green
Yellow - Yellow
Black - White
I gathered this info from a couple of websites, but I would appreciate it if anyone with a post 89 Supra can verify that is how their wiring is connected.
So if your wiring is correct, and your mechanical timing is set, and your CPS is installed as described in the link above, have someone crank the car as you slowly turn the CPS. If you get it to fire, try to keep it running with some adjustments at the CPS. If that works and it runs at idle, let it warm up and set the ignition timing as described in the MKIII FAQ
