Thread: issues
Old 05-07-2012, 07:11 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
I had a 87 N/A auto that used to stall out at lights, turned out to be a combination of vacuum leaks, vacuum lines routed improperly, and a TPS out of adjustment. I'd check those 3, in that order. I'd also get that alternator load tested, because that sounds like it could be part of your dying problem. Also make sure your battery connections are tight and corrosion free
