Old 04-28-2012, 03:00 AM   #1
Green7mgte
Supra Forum Moderator
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
the black box is sort of hard to break unless one goes dicking with it.. trying to "clean" it's optics by spraying something in there and wiping it off.. most likely cause is a faulty wire. I'd start there.
helping to rule things out.. your ecu is not the culprit.. those things don't generally break.. So that just leaves.. your afm. or your afm circuit.. the box or its wires.. check the voltage and you have your answer
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
