Old 04-26-2012, 04:53 AM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Bone stock you'll see about 6 PSI of boost. To get more than that, you can upgrade your exhaust, install a boost controller, upgrade the turbo, shim the wastegate (I personally don't recommend this method).... Basically, there are several different methods to increase boost pressure. I believe the easiest way to gain more boost would be to buy or construct a manual boost controller. This method also allows you to adjust the amount of extra boost, depending on your needs.
With all that said, I wouldn't recommend running much extra boost on a tired 24 year old engine; extra boost equals higher combustion chamber pressure and stress, which typically exposes hidden problems (such as a weak head gasket). Make sure your engine is healthy and in good running condition before trying to force more power from it.
