are you reading any codes? if so i would check the FAQ'S to see what they are and that might help zero in on what your problem might be
it may just be ready for a rebuild
that might also be it. did you just get the car, are you first owner any info about it would help
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
