Old 04-24-2012, 10:55 PM   #1
pandrade
pandrade is on a distinguished road
the 7mgte came whith a mechanical fan but also ( depending on the year) one or two electrical fans on the drivers side of the radiator. i myself installed a aluminum road raceing radiator for cheap insurance agenst overheating at events. i would reinstall the oe fans if you have some lying around
don't fit on between the fan on the belt and radiator what should I do
i dont quite get what your asking. did the guy befor you butcher the oe conectors and now you cant use them?
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
