Thread: Random stalling
Old 04-15-2012, 11:48 PM   #34
Nothing wrong with that at all I recommend it depending on the issue. I don't think it's the problem here though, but go ahead and try. I recommend you bypass at the bigger round connector as that will bypass both resistor and relay. Use an appropriately large gauge wire and a couple spade connectors to make a reliable and easy to remove bypass wire. Refer to the TEWD to see which two contacts you want to jumper.
