Old 04-15-2012, 08:38 PM   #1
pandrade
pandrade is on a distinguished road
Well If you hitting fuel cut off then you know your going to it's limits. Which I want, I'm tring to see if any local shops can do the same thing for cheaper. Might as well shop around first befor droping 400$. How's the spool up whith the ddp
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
