what cre said,
wat about extending a pipe off the afm, and putting the cold air intake by the bumper
but i would think that if you put the filter at the bumper rain, debris, speed bumps, sand/mud and alot of other stuff would come into contact whith you filter and that would need constant replacments. unless you fabed a shild of some sort
this is what i initaly thought, correct me if im wrong
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
