Old 04-13-2012, 09:30 PM   #1
pandrade
pandrade is on a distinguished road
i actuly started a thread about this earlier in the year heres the link. hope it helps, im still making the molds to get the fit right
http://www.toyota-supra.info/forums/...e-air-box.html
basickly you could make a hose going from the stock snorkle hole to the bumper to get freash air,the way i would do it is to remove the pasanger side fog light make a velocity stack and run a pipe up to the snorkle hole which is followed by the box which keeps the hot air out i would make the box that houses the filter element out of fiberglass since it doesent heat up like aluminum does ( race cars use it because there always moving air never standing still like a daily would) if you get aluiminum pipes wrap them in exshaust wrap to keep the pipes cooler
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
