Old 04-04-2012, 03:45 PM   #4
pandrade
pandrade is on a distinguished road
i belive earlier he recomended not using drilled and sloted if its daily but if you take the pads and rotors and only use them for the event i would go whith power slot's sloted rotors and yellow stuff pads( but i dont have that kind of money so blank rotors and leaving the yellow stuff on all the time)
cre whats your take on this
only sloted and drilled if you take them off whith race pads, if daily driver leave the pads on whith blank rotors?
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
