Old 04-04-2012, 11:42 AM   #2
pandrade
pandrade is on a distinguished road
Thanks for the help Cre I apprichiate it. One more question originally the mk3
factory calls for semi metallic (better pad ) and organic in rear (a bit weaker) the ebb guild says if you put yellow in front you can pair it equally in rearor got whith red and ultimax should I pair front and rear yellow. Or should I put red in rear to keep a close factory bias or wouldn't really matter
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
