Old 04-01-2012, 02:24 AM   #1
The idle is computer controlled and not to be manually adjusted. If the idle is wandering like that there are a few possibilities. I suggest you begin with checking for diagnostic error codes (covered in the FAQ section) and inspect for leaks in the intake plumbing, PCV and vacuum system.
