Thread: 7M pan bolt
Old 03-30-2012, 03:07 PM   #1
DawgB0
DawgB0 is on a distinguished road
Didn't u research why? Its most common problem. If you are in cold situation then maybe its because the gasket is cold makes it leaking somewhere you couldn't see then when it got warm it went away? Then yup you will need new gasket so this problem can go away and use correctly torque then should be no problem. gud luck
92' 7mgte MT st8 bakcat
DawgB0 is offline   Reply With Quote
