Old 03-27-2012, 02:25 PM   #1
pandrade
pandrade is on a distinguished road
i would take the actuator motor that is on top of the shocks and have a buddy press the buttons to see if the actuators move acordingly, the front is 3 nuts and its off. the back is a pain because you have to take the side panels off the trunks interior to take the motor out to check but this is in my 87 which i belive had bigger and bulkier actuators than 89 and newer the newer models you might be able to squeez out of the pre cut hole since there smaller
any one correct me if im wrong since i would like to know
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
