Old 03-24-2012, 08:11 PM   #1
interested!
Wink crankshaft problem.
Originally Posted by Life is Supra View Post
Thanks a lot I hope we understand each other,by the way I must ask you can I drive it like that or must pull it to garage because I fear that can do some damage on the engine?
Hi!, I would recommend repairing very soon , the longer it's left , the more the crank is being damaged by the " coning " action of a wobbling pulley. Create a tube and spigot , the tube inner diameter is the diameter of the crank at it's smallest , the spigot should be a sliding fit inside the CRANK thread and this is cut down as the crank is filed and the spigot bottoms out until the tube face reaches the timing belt gear. Check the face of gear and pulley for damage and replace the gear if any damage found .The spring is used to stop the tube jamming on the crank .
ID:	4516   Click image for larger version
ID:	4517   Click image for larger version
Last edited by interested!; 03-24-2012 at 08:49 PM. Reason: extra information about the tube and spigot.
