Old 10-13-2005, 03:27 PM   #1
SupraMan1784
SP58GT
i have the aquamist water injection on my supra..it brings down teh temperature of the combustion chambers a lot...cooler mixture in other words, it does allow you to run a higher psi before pinging since the mixture will be cooler even after running through an i/c, therefore it allows u to run pump gas on a high amount of boost, though i still run 93 or 96 to avoid knock and preignition, i think its well worth teh money and you get to make more power
Now: Saving for an MKIV
Broken Rides:
