Old 03-15-2012, 02:32 PM   #2
Sonyps307
I talking about running the oil drain to the electric oil pump then to the hole that is already in my Oil pan that the 7mgte use as the cooler return. I'm going to use the inline oil pump to pull the oil out the turbo then push it into the pan. I think that the oil pump should be able to push the oil in the pan weather the hole is covered by oil or not. I was talking about the sts turbos because they use the pumps to get the oil out of the turbo mounted in the rear of the car back to the motor.
