03-14-2012, 02:50 AM
#34
Supra Owner
Originally Posted by warmkop
I want to change the valve stem seals before i start assemble is it just better to take the head off or do i try to do it with the head on.I got a gasket set the make is evergreen automotive do you know it.The valve stem seals is worn out because of the crap that is in the head.If i must take it off il get ARP head studs and take the head in to get clean.thanks.
http://bellsouthpwp2.net/p/w/pwpanas...ra%20Turbo.htm
Life begins at 30psi.
