Old 03-05-2012, 06:55 PM   #2
Shake loose? Not in the MKIII. They'll oxidize, get frozen together, or wiring may get melted... It's quite seldom that you find wires which have vibrated/shaken lose. The connectors Toyota used are VERY solid. One common complaint with regard to the CPS/distributor is the wiring getting damaged from heat from the exhaust manifold.
