Thread: how much power?
Old 02-29-2012, 02:40 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by deigima View Post
come on dude, get to the point. no bs, just tell me
Stock twins, 6spd: 350rwhp on pump gas
76mm turbo (or bigger), 6spd: 700rwhp on pump gas
However, with the 76mm turbo, running 15psi on pump gas, you'll be running 220rwhp until you hit about 5500 rpm or so. You'll be living in turbo lag city, and it'll suck donkey b@llz.
Can you see now why I was trying to find out more about your setup? There is no one clear answer...it depends a lot on the turbo you'l be running, and your application. Maybe rediculous turbo lag won't be a factor to you, if all you'll be doing is drag racing - just drop the clutch at 6k and keep it at redline through the whole 1/4 mile. Or maybe you want to stay with the stock twins because of the cost of a single turbo and fuel system upgrade, so you'll be stuck at 350rwhp. This sh*t ain't BS buddy...it's critical information and there's no way to properly and correctly answer your question without knowing it all.
Life begins at 30psi.
