Old 02-27-2012, 10:07 PM   #1
MJG
MJG's Avatar
FYI.
I have that IC in my car. The kit is not a "plug-n-play" kit and numerous modifications will be required to install it.
Oil cooler and horns will require re location.
The stock coolant over flow tank will not fit in the origional position. I replaced it with an aluminum tank, custom made for my application.
The top IC bracket (supplied in the kit) required modification to fit in the car.
The pipe from the left side of the IC (charge air out) that runs under the IC to the fender well pipe (right side) will interfere with the plastic engine under cover. I modified my undercover to work with the pipe.
All of the IC pipes fit well without modification. Stainless "T" bolt clamps are supplied and the couplers are decent.
NO instructions are provided. It is assumed the installer has the required tooling and skill to install this kit.
All in all, it is a nice kit and worth the effort.
