Old 02-25-2012, 07:11 AM   #1
bandit1730
bandit1730 is on a distinguished road
Default $35.00 Low-Cost Toyota Solution to VSV replacement
Had the same problem with the VSV solenoid being busted on my 89 turbo. Searching on the net, came around this post http://www.supras.com/06/techcenter/display.php?QID=58 . The part costs around $35.00 from Toyota (for Camry). It is the same solenoid, but the connector is different. Just cut the old VSV connector/wire as close to the VSV as possible and solder two standard female connectors (like the ones used on speakers) and you are good to go on the freezing cold.
Toyota part # 88690-32280
bandit1730 is offline
