Old 02-20-2012, 07:48 AM   #4
The oil pan isn't supposed to be installed with a gasket and I can assure you with great confidence that it is MUCH more likely to leak if you use one (such as the one which Fel-Pro includes). Use Toyota FIPG as directed in the TSRM, Honda's FIPG is quite good too or "Right Stuff" (the kind in a compressed can)... You'll also be using this on the #1 cam caps and at the union of the head and lower rear timing belt cover (DO NOT FORGET TO APPLY FIPG HERE!!!).
