Old 02-16-2012, 01:10 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Sturbo View Post
Well, well there is some turbo kits on 2jz ge engine for lexus gs300 and achieve some results. how they do it, as far as I understand it, most pistons and head gasket, or simply laying his head, and the unit does not conduct nor any reinforcements. (I respect your vyskazivaniya and advice, do not get me no true test for me is very vvzhno), I just want to know whether the engine 2jz ge, to withstand the installation of the turbine with the replacement of the piston head gasket gte 1.4 mm, with ARP bolts, replacing fuel injectors, fuel pump replacement on wallbro, (intercoolers, candles, intake and exhaust manifolds, it is understandable) and of course the ECU, but I do not know exactly what to order to uprovlyat all.
Apologies, I do not understand the following (are you using translation software?):
- vyskazivaniya
- vvzhno
- uprovlyat
- your use of the word "candles". To me, a candle is a stick of wax with a string inside.
If I have interpreted your meaning correctly, then I believe you do have the correct set of upgrades specified. However, even with the 2jz-gte pistons and connecting rods swapped in, you will not achieve the same results as you would have with a 2jz-ge. The 2jz-ge's (non-turbo) ignition system, the 2jz-ge normally-aspirated head, and the lack of oil squirters in the block will still limit your results.
Life begins at 30psi.
