Old 02-13-2012, 02:25 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Sturbo View Post
Hello everyone. Advice please.
I thought 7mge turbocharged engine and found that these engines have a problem of oil starvation in two cylinders. After that I thought put the 2jz-ge + installed on this engine turbine as 2jz-GTE its price is very high than the 2jz ge Who knows what is necessary for instolyatsii turbine?
It's much easier to turbocharge the 2jz-gte due to it's lower compression ratio. Also, the 2jz-gte has oil squirters to cool the pistons, which also helps the engine to dissipate the additional heat associated with the higher turbocharged horsepower levels. Lastly, the 2jz-gte's head flow- especially the intake side, is superior to the 2jz-ge.
Life begins at 30psi.
