01-21-2012, 01:30 PM
#1
Supra Owner
Originally Posted by priyesh12
Thanks I really appreciate it,
Okay, I have 1996 twin turbo supra JDM with the manual 6 speed transmission.
I think I can clear up the question even more, from my understanding all I have left to install is the turbo timer part. So I need to find and connect to ignition 1 & 2 with the wires from the device to finish this setup, the question is which wires can I tap into on my ecu to make the magic happen. Or do I have to connect the wires to the stock harness underneath the steering wheel, even there which wires would I have to tap into...hope this helps
If it helps, here are the us-spec tech articles for boost controller, fuel cut controller, and turbo timer installation:
http://www.mkiv.com/techarticles/bcc.../bcc_intro.htm
http://www.mkiv.com/techarticles/fcd/fcd.htm
http://www.mkiv.com/techarticles/avc...all/index.html
http://www.mkiv.com/techarticles/blitz_dsbc/index.html
http://www.mkiv.com/techarticles/hks...urbo_timer.htm
Life begins at 30psi.
