Old 01-11-2012, 02:29 AM   #1
Bulkierzero
Bulkierzero is on a distinguished road
I take it you mean that you're trying to remove the thermostat neck/tower? There are three studs which hold it in place and then there are a terrible hose which connects to the bottom side. This may help: http://www.cygnusx1.net/Supra/Librar...spx?F=1603&P=2
Does the hose have to come off before you can pull it off? I loosened the hose clamp in hopes that i could remove the tower then disconnect the hose
Bulkierzero is offline   Reply With Quote
