Old 12-31-2011, 01:37 AM   #34
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
It is EN 24 codisin T mild steel and it is 17.132kg
That should work fine. Be sure to note that if you're going to be using a carbon-ceramic clutch disk material that you'll likely wear that flywheel out quickly if you're doing a lot of drag racing. The carbon-ceramic material is *much* harder than mild steel.
Life begins at 30psi.
