Old 12-29-2011, 01:02 AM   #1
Good lord... pretty much EVERY post in the MKIII forum has me as the last person to respond... I need to get away for a while. (Granted, a lot of those are because I've been moving threads from other forums to this one and I've just posted indicating as much...)
Anyway, back to your question.... YES, they use the same fasteners. When in doubt check the part numbers for the OEM components with your local dealer or the EPC. All 7M's use 13265-42010.
Even if ARP had a different set for the GE the GTE would undoubtedly be the more robust option... so you can buy with confidence.
