Old 12-27-2011, 08:08 PM   #1
Posted in the wrong section. Do not post in FAQ forums; If you are unsure if you are posting in the correct area read the description for that section first.
Thread moved.
Answer: a small prybar or large screwdriver at the extension in the front of the engine on the driver's side; Right behind the timing belt and i front of the crankcase breather.
