Old 08-27-2007, 06:21 PM   #1
jarekt
jarekt is on a distinguished road
Question high pressure in cooling system
I'm wonder if anyone can help diagnose high pressure of gases in cooling system.
Car is running great, still after approx 100 miles on HWY temp is going up.
I can't see any oil in coolant or coolant in oil system. Still there's very high pressure of gases (air?). To be more specific, driving on 5th, 100m/h is not a problem, only as soon as i idle engine, temperature is going up. accelerating will bring tmp down again. When engine stop, there's a lot of spill from overflow tank and i can release a lot of steam from radiator!. When engine is cool, coolant from overflow will go back to radiator.
There's not "white" smoke from pipe, no lost power.
one more: on old engine i have "burbling" noise in core heater. This sound didn't go away when i installed new engine two years ago.
Any ideas?
BTW When it happed first time, i replaced thermostat.
jarekt is offline   Reply With Quote
Old 08-27-2007, 09:01 PM   #2
IHateHacks
IHateHacks's Avatar
Your head gasket is leaking. Actually, the head gasket is warped around the exhaust side cooling passages.
But you don't have to take my word for it. Run a block test to confirm
Old 08-27-2007, 09:13 PM   #3
jarekt
Default test
how i can run block test? just cylinder pressure?
Old 09-01-2007, 06:39 PM   #4
mrnickleye
mrnickleye's Avatar
Unhappy Bhg
No. Have a shop perform it. It is a special liquid that is used at the radiator top, and can tell if gasket is blown.
OR/AND....the radiator top can be sniffed by an exhaust gas analyser. Hydrocarbons means exhaust gasses in the cooling system....means BHG.
PS: Your symptoms are exactly what mine were, $800, my labor, 2 1/2 yrs ago.
fuel pressure boost32 Non-Generation Specific Questions 1 08-10-2008 10:19 PM
Coolant system pressure igosaur MKIII Supra 2 09-08-2007 07:10 AM
burping the cooling system from air bubbles suprra_girl MKIII FAQ 2 04-19-2007 05:40 AM
Cooling system problem vancouver874 Non-Generation Specific Questions 2 07-17-2006 03:43 PM
