Old 01-18-2007, 03:28 PM   #1
marxdenning
marxdenning is on a distinguished road
Unhappy stalling under load
Hi,
I have the 1990 supra turbo 7mgte and i'm experiencing problems with idle/stalling. If i start the car it is fine and ticks over at 700 to 1000rpm, if I am doing a constant speed or decelerating then drop the clutch it is fine. However if i accelerate then drop the clutch the revs will momentarily drop to about 400 or stall, even if it has only gone from e.g. 1 to 2mph or 40 to 41mph. I do not have to put the pedal to the floor for this to happen, only enough for acceleration. It has been an ongoing problem for many years now and i have replaced several parts which include: egr valve and the other brown coloured valve it connects to, afm, replaced the idle valve with a secondhand one, fpr, o2 sensor, ecu was tested, turbo, sparkplugs, cleaned the three coils, ht leads, full exhaust system, had the injectors pressure tested, air filter, gearbox, checked several times for air leaks with no joy, it had an engine rebuild (not the rings) including the head and block being skimmed a few years back but all of these items were after this problem arose. I am at a loss and could really do with some help from the experts on this one.
Many Thanks
Marc
marxdenning is offline   Reply With Quote
Old 01-18-2007, 09:51 PM   #2
IHateHacks
IHateHacks's Avatar
What's your fuel pressure at? I see you tested or replaced a bunch of items, I'm sure you tested the fuel pressure right? If not, I'd start there.
Have you ever replaced the fuel filter? I didn't see that listed. They should be (and I emphasize SHOULD) replaced every year or 12,000 miles.
You said you cleaned the coil packs but have you checked them with a volt/ohm meter? Thats the only way to tell if they are operating correctly. Same with the plug wires.
vibrations under load mike_j_2me MKIII Supra 3 11-16-2007 05:21 PM
Stalling Supra djairam MKIII Supra 11 11-22-2006 05:19 PM
Random stalling of the engine?? XtreeX MKIII Supra 20 11-15-2006 06:14 PM
Stalling 88 turbo White targa MKIII Supra 3 01-01-2006 12:47 AM
Stalling Supra Guestalby MKIII Supra 9 04-21-2005 02:21 PM
