Old 12-14-2006, 07:22 AM   #1
barrow_eric
barrow_eric's Avatar
barrow_eric is on a distinguished road
Post Targa top leak estamite $$
Hello everybody. I am looking at buying a 1988 supra turbo. Everything is in great condidtion the only problem is the targa top has a water leak just on the pasenger side. According to the owner hes tried to fix it, but im not sure to the exstent. I was wondering if anybody could give me a maximum estimate it would cost to have the targa top fixes by someone profesionally, or fixed period? Or any other sujestions. i have looked in other treads, but found little information about cost.
Thank you.
barrow_eric is offline   Reply With Quote
Old 12-15-2006, 03:14 PM   #2
ARZ
ARZ is on a distinguished road
Go to SM and look for Supragirl she is from New Zeland I think she replaced those seals when she painted her car.
Also I used to make cars convertable as a side job and the way we would do it is to scuff the rubber in the questionable area with 36-60 grit sand paper. Get some black RTV and add silicone and shape it to the desired shape using syliva on your finger, for some reason syliva works pretty good at keeping the silicone from sticking to your finger as you work it. Then when it is starting to set up get a sandwich bag and put it over the soft silicone and close the doors and windows and let it setup a couple hours. If it dosent do the trick trim it off with a razor and try again.
Keep a couple of clean paper towels handy during the whole ordeal, Silicone spreads everywhere. Throw each papertowel away as soon as you finish wiping your hands. If you dont you will be shocked at how far the silicone spreads.
ARZ is offline   Reply With Quote
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Oil Leak Question kidsusukigsxr Non-Generation Specific Questions 2 06-26-2007 03:17 PM
everyone who has a targa top..quick help please. lazy alex MKIV Supra 2 06-23-2007 12:09 AM
