Old 12-12-2006, 07:38 PM   #1
suprascott
suprascott is on a distinguished road
Default gear shifting problem
hey guys, i have a 1988 toyota supra 3l manual, iv had it for 6 months and now have encounted a problem, the other day when driving i found it hard to change into 3rd gear and the same into 4th! i changed the clutch cylinder on the side of the gearbow (cant remember if its the master or slave) 5 months ago because of a leak. the car drives fine now, i pumped the chutch for a few minutes yesterday because i thourght it could of possibly been an airlock (as i top the fluid up every 6 or so weeks). Could that be the problem or is it likely to be something else?
suprascott is offline   Reply With Quote
Old 12-15-2006, 03:05 PM   #2
ARZ
ARZ is on a distinguished road
If you top the fluid off every 6 weeks you definately have a leak. Thats your problem. The Toyota manual transmissions are renowned for their syncros basically you are not disengaging the clutch enough and the syncros are doing the rest.
The Master tells the slave what to do, think of it that way. So the master cylinder is on the firewall, the slave is on the transmission.
ARZ is offline   Reply With Quote
Shifting Issues (Automatic) btwilson86 MKIII Supra 4 11-03-2007 07:05 AM
quick question blacksheep Non-Generation Specific Questions 10 01-01-2007 08:19 PM
gear shifting problem suprascott MKIII Supra 1 12-13-2006 04:10 AM
Manual Shifting Trouble KingJames224 Non-Generation Specific Questions 3 10-22-2005 09:26 PM
