Old 05-09-2006, 09:21 AM   #1
SU9RA
SU9RA is on a distinguished road
Default My Engine Light Flickers On And Off
i am new to this site and relativly new to supras i bought a 1990 single turbo 7MGTE supra all stock when i boughtit! it was running perfect but once i boosted it to 12 psi got the turbo hiflowed and got the auto done (fully manualised trimatic auto with a 3,000 stall converter) i find that under load like shifting from 1st to 2nd the car sort of cuts out ond the engine light just flickers on for a seccond then goes off again!!!! i was told it was the speed sensor and got it changed but i still have the problem, i was also told i had a boost cut off at 10 psi took the boost down but still it happens!!!! so it is currently at the work shop getting a new fuel pump, computer, bosh 550 injectos, cooler and exsorst..... i hope to fix the problem would anyone be able to think of what it could be?????
any views or ideas would be much apreciated thanks
SU9RA is offline   Reply With Quote
