Old 04-14-2006, 03:12 AM   #1
Fuel
Fuel is on a distinguished road
Default overheating
Alright i just got my car back from the shop after it had a used engine put in. It gets kind of hot, well i think it gets hot, the gauge reads about half way or alittle below 3/4. That seems hot to me. I dont know if it is or not. This is after the mechanic made the little fan run all the time, other wise it would get hotter. I thought that was for the air conditioning? I am really confused on whats going on so any and all help would be appreciated.
Also next time i get paid i want to replace the clutch fan with a race flex fan and a thermostat that opens at 170* or 180*.
Fuel is offline   Reply With Quote
Old 04-14-2006, 10:36 AM   #2
ddmcse
ddmcse's Avatar
Cool
take it back asap
don't let that temp get that high anymore
you have a real problem and need to get it fixed make the repair shop chekc it out.
adding fans and leaving fans on will only cover up the problem
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 04-17-2006, 03:01 PM   #3
Fuel
I have taken it to 2 shops and both of them have said nothing was wrong. My question to you guys is what could be wrong? MY water pump is fine, thermostat works, and my block is not cloged.
Old 04-17-2006, 04:48 PM   #4
Benesesso
Benesesso's Avatar
Benesesso is on a distinguished road
I have 2 turbo supras and used to have a NA one, and they all ran on the warm side. I'm having a custom ($400) 3-row "high efficiency" radiator made for my 1990 right now. Interesting that Toyota added another AC fan in 1989 or '90, because my '88 only has 1 (electric).
My Supras ran hot at real low and real high speeds-running "normal" in low traffic wasn't a problem. IMO the stock rad. is way too small--but I'm in Arizona.
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
1988 and 1990 Turbo Supras
Benesesso is offline   Reply With Quote
Old 04-17-2006, 08:52 PM   #5
ddmcse
ddmcse's Avatar
Cool
put a real gauge on it
you might not like seeing what 3/4 of the stock gauge equals =on a real gauge
i use a 160 stat
i have a fluidyne radiator
it mostly stays around 180 - 190
are you pushing any water out anywhere ?
my stock temp gauge has never worked correctly for the 10 years i've had my supra
My Supra KiXGaS
Old 04-19-2006, 03:13 PM   #6
Fuel
No I am not leaking any water. I guess I could just be paranoid about seeing the gauge that high. On my truck the gauge never reaches half way. But I will take your advice. Thanks
Old 04-19-2006, 03:32 PM   #7
ddmcse
ddmcse's Avatar
pull the oxygen sensor and see if it's coated white
My Supra KiXGaS
Old 04-21-2006, 04:11 PM   #8
Fuel
Hate to be a real noob, but where is the O2 sensor?
Old 04-21-2006, 05:53 PM   #9
ddmcse
ddmcse's Avatar
it's bolted into the elbow turning down at the backside of the turbo
the turbo is on the exhaust side , you prolly have a heat shield all around it
http://www.ddmcse.com/turbo/images/is_it_in_yet.JPG
see the turbo in this pic ? the oxygen sensor would be right behind the turbo ..see the yellow clip hanging there ? thats where the sensor connects . heck now that i think about it .
i have an extra one that i bought to troubleshoot .. stock from toyota is not cheap and never is
My Supra KiXGaS
Help... my car is overheating suprra_girl MKIII FAQ 40 07-11-2010 06:51 AM
82 Supra overheating suprahusker MKII Supra 2 10-17-2007 01:59 AM
2 Questions: 1 About Overheating, 1 About HeadUnit Adaptor V1P3R MKIII Supra 9 07-17-2007 05:26 AM
car overheating marc MKIII Supra 11 06-30-2006 05:55 AM
Need Help, Overheating Problems MDellboy420 MKIII Supra 9 12-19-2005 06:46 AM
