Old 01-05-2006, 03:29 PM   #1
Donnies Foreign Car
Donnies Foreign Car is on a distinguished road
Question 89 Supra Turbo w/1JZ Swap Problems
Need some help from others that might have experienced this problem. The car is a 1989 USA Spec Toyota Supra Turbo. The new engine is a JDM 1JZ swap. The problem is with the headlights, marker lights with the car running. With the car off you can turn on the headlights and everything works exactly right. If you start the engine and the voltage stays at normal at around 14.4 or so then the headlights, marker lights, tail lights all work okay, but if the voltage drops, the headlights start going up and down and the headlights flash along with all the other lights. The alt as been checked out and it is good. The voltage regulator is also good. Please if anyone can help this would be great. Thanks Jeff
Donnies Foreign Car is offline   Reply With Quote
Cheap Na to turbo swap supraman121 MKIII Supra 0 12-07-2006 08:03 AM
1986.5 Toyota Supra Nppn Turbo- New Turbo Help ! DarkRaiderz MKIII Supra 6 12-27-2005 09:04 PM
