Old 11-26-2005, 03:38 PM   #1
Rich87
Rich87 is on a distinguished road
Default Engine timing
I have a rebuilt 1987 supra that I can't get to meet factory timing. It will run half decent, but is sitting at about 20 degrees before TDC. factory is 10. Anyone else have or see this problem?
Rich
Rich87 is offline   Reply With Quote
Old 11-26-2005, 06:13 PM   #2
mrnickleye
mrnickleye's Avatar
Are you jumping the connector to set the timing? Yes? Good. Then manually set it at 10-15*, then remove jumper wire. I run 15* on my n/a with no problems.
