Old 07-02-2009, 04:41 AM   #1
eandjautoworks
eandjautoworks is on a distinguished road
Default Antifreeze Leak behind engine on non turbo 87 3.0L supra
So, I just picked up a 1987 Supra and I was putting a new exhaust on today and I finally got it done and it started smoking really bad. I looked under the car and under the hood and I could hear antifreeze sizzling on the exhaust. I noticed the water pump is in the front and obviously the radiator and thermostat are as well. I looked at the top hoses for the heater core in the back and they looked fairly new. I am not too familiar with Toyotas and I haven't found any useful information on the coolant system. It is more on the passenger side than the driver side. I was wondering if anybody had a picture of the back of the engine or any ideas where the leak may be coming from. I really would like to get it fixed by tommorow so please give me any information on it that you may know. Thanks.
Eric
eandjautoworks is offline   Reply With Quote
Old 07-02-2009, 09:45 AM   #2
Cool
you need a repair manual
http://www.cygnusx1.net/Supra/Librar....aspx?S=CO&P=2
Old 07-02-2009, 02:36 PM   #3
eandjautoworks
Hey, I appreciate your help. That site was very helpful. I just needed to figure out what hoses went back there. Thanks
Old 07-03-2009, 12:05 PM   #4
Bill UK
AEM EMS
Bill UK's Avatar
This may help.
Old 07-03-2009, 09:53 PM   #5
eandjautoworks
That diagram was very helpful. There ended up being a leak right there at the elbow that goes into a metal line to the head. Thank you
Old 07-03-2009, 10:28 PM   #6
mirage83
If you can find the room to get there, you might want to replace that heater union bolt that goes into the head there while you're replacing that hose. They tend to corrode, and aren't much fun to get to.
Old 05-12-2018, 05:13 AM   #7
Bad bronco91
Bad bronco91 is on a distinguished road
Did u buy a new hose for it if so were did u buy it from I have the same problem on my 82 celica supra an talked to toyota an they cant even get one factory anywere in the us said I had to buy aftermarket an i cant find it anywhere
Bad bronco91 is offline   Reply With Quote
1990 supra turbo engine issues help jespat Non-Generation Specific Questions 4 01-24-2008 02:37 AM
transplant a 3.0 celica supra turbo engine Carl_Silva MKII Supra 2 10-27-2006 08:30 PM
