Old 10-11-2008, 04:38 AM   #1
jrok
jrok is on a distinguished road
Default code 34 turbo pressure
i understand alot about the way the ecu works but what is happening when code 34 triggers is it maxing out the fuel system, i havn't read the vf reading yet when it happens, i just shimmed the waste gate and runs steady 11 lbs but hit 13 at about 5 grand in 5th gear. when the code triggers its under load before the 13 lbs... any info would be great...
its 7m-gte with custom intercooler and other than that pritty much stock ,rebuilt bottom end and new head gasket
1984 celica supra with 7mgte swap, custom intercooler, 2.5 exhaust no muffler or cat, shimmed wastegate to 12 lbs boost, with r154 turbo 5-speed tranny 16x8 xxr s13's with 245/50R16 toyo proxes 4's
.http://au.youtube.com/watch?v=rgOxP0PxCwo
.http://au.youtube.com/watch?v=uf989mb3EDw
also own:
2000 4runner 3 inch lift, 33inch tires
.http://au.youtube.com/watch?v=J15k1rCh7-A
1988 4runner stock
.http://au.youtube.com/watch?v=2u7e1_pMqfs
.http://au.youtube.com/watch?v=9lu4j5P6M7M
jrok is offline   Reply With Quote
fuel pressure boost32 Non-Generation Specific Questions 1 08-10-2008 10:19 PM
