Old 04-15-2008, 01:57 AM   #1
elsleepster
elsleepster is on a distinguished road
Default Transmission leak
85 Supra has a small leak- Is there a manual 'stop leak' transmission fluid?
elsleepster is offline   Reply With Quote
Old 04-15-2008, 03:20 AM   #2
mrnickleye
mrnickleye's Avatar
No. You need to pull the trans and re-seal it.
Old 04-27-2008, 11:40 PM   #3
elsleepster
Question Transmission filler plug
Thanks for the response. Man, transmission repair is not cheap.
Anyway, I was trying to find the filler plug to check the fluid level. Any idea where this is located? I think I found it but not sure- Is it located on the drivers side center of the drain plug? This plug will not budge so I wanted to make sure it's the right one before I start bustin my knuckles!
Thanks again
(85 Supra 5sp non turbo)
1986 Turbo Automatic Transmission Rebuild? professorbob MKIII Supra 2 01-26-2012 01:06 AM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Blown transmission 1985Supra MKII Supra 2 01-31-2007 07:56 AM
