Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 05-09-2005, 11:28 AM   #1
supersupra
supersupra is on a distinguished road
Default 7mgte or 1jz-gte???
i know that the 1jz is a jdm engine and the 7mgte a usa spec, though i'd loke to know which one is more powerful (i know jdm model cars are usually better, but by how much in hp? :huh: )
supra+girls+happiness=<span style='color:blue'>A LIFE</span>
supersupra is offline   Reply With Quote
Old 05-09-2005, 09:23 PM   #2
the_fallen
the_fallen is on a distinguished road
suprragirl will know more about the 7m specs then i do, but the 7m came around about 230hp in turbo form. the 1jz came 280 (japanese self inforced limit)
the_fallen is offline   Reply With Quote
Old 05-09-2005, 10:45 PM   #3
jza80 Supra C-I TT
jza80 Supra C-I TT is on a distinguished road
yeah i think u should wait on suprra girl. my sousin said she knows all about them. but if i were u i would go with the 1jz
[img]http://rds.yahoo.com/S=96062883/K=supra+logo/v=2/SID=w/TID=I001_70/l=IVS/SIG=127fv51d7/EXP=1118546922/*-http%3A//www.supra.racingteam.kessler.com.pl/logo.jpg[/img]
<span style='color:green'>300 horsepower is 299 too much for any camaro</span>
MKIV POWER *cough* suprra _girl *cough cough*
jza80 Supra C-I TT is offline   Reply With Quote
Old 05-11-2005, 01:30 AM   #4
monkihead
SP58GT
monkihead's Avatar
the 7m (from my research) isnt as powerful as the 1jz. but i plan to keep with the 7mgte
monique- better off dead
Old 05-11-2005, 04:05 AM   #5
supersupra
thanks guys, even if the 1jz is better standard, isnt the 7mgte bigger (3 litres verses 2.5 litres??? )
Old 05-11-2005, 08:11 PM   #6
monkihead
SP58GT
monkihead's Avatar
if the 2.5 is capable, you may be able to bore out the cylinder to make it a 2.6 or 2.8. it would change your compression ratio, but you'll gain power in different rpm ranges.
Old 05-18-2005, 01:15 PM   #7
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
yep the 1jz has a headstart on power... 50bhp, they're awesome engines.. great for the track
but 7m power is where it's at :lol:
the 1jz for being .5L less is quite surprisingly powerful... but power can also be made from the 7mgte
check out www.7mpower.com hehe
Pics of my build.
Do a diagnostic first!
Old 02-09-2011, 09:54 PM   #8
bdavis89
bdavis89 is on a distinguished road
im a bit rusty on my specs but doesn't the 7m have more torque?
bdavis89 is offline   Reply With Quote
Old 02-23-2011, 11:11 PM   #9
spunkenhimer
spunkenhimer's Avatar
spunkenhimer is on a distinguished road
dude the thread is like 6 years old just to let you know! make a new one if you don't know for sure.
spunkenhimer is offline   Reply With Quote
Old 02-24-2011, 04:36 PM   #10
Travis89Turbo
Travis89Turbo's Avatar
No. A lot of people assume that because of the .5l less. But the jz actually puts more to the ground then 7m.
But the 7m makes max torque 400 rpm sooner then 1j which is where the confusion starts
Factory specs at crank,
1jzgte= 280 HP. At 6200 rpm 268 ft lbs. At 4800 rpm Now the factory way under estimated this motor. Mine 100% stock put down. At the WHEELS. 285 HP. 272 ft lbs
7mgte= 232 HP. At 5600 rpm. 240ft lbs at 4400 rpm
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
HTML code is On
Twin turbo on 7mgte? supraman121 MKIII Supra 7 08-24-2007 02:12 PM
7mgte and 7mge question supraman121 MKIII Supra 2 01-12-2007 09:09 PM
7mge to 7mgte kallmijonx2 MKIII Supra 2 10-22-2006 12:55 PM
