Go Back   Toyota Supra Forums! Join the Supra forum! > General Discussions > Supra FAQ
Old 03-18-2007, 07:25 PM   #1
mrnickleye
mrnickleye's Avatar
Thumbs up Cleaning the PCV System
You can do the PCV your self.
Get a can of spray carb cleaner from wally world or parts house, 99 cent. Remove the metal tube and rubber hoses. Spray clean the tube. Spray some cleaner into the throttle body.
Use some new rubber hose (3) if needed. Toyota wants too much. You can use fuel line, or A/C hose (from parts store) that fits.
Heater hose will eventually (sooner than you'd like) soften up, as it is not for fuel/oil vapor.
Before re-installing, place one end onto the throttlebody, place finger over one open hole, then blow into the tube to make sure the passage is open. If it does not blow easily, spray some more cleaner, then repeat the test.
Now replace tube/hose assy back into position. Start car. It will probably stumble a bit from the carb spray, so rev it up a few times.
Old 03-21-2007, 01:58 AM   #2
IHateHacks
IHateHacks's Avatar
What about the PCV passages in the cam covers? When I had mine off for the 2nd time during my head gasket replacement you should have seen the amount of sludge in there. I actually had to scrape it out with a screwdriver. Serious restriction.
If you have over 100k miles I highly recommend removing the cam covers and cleaning out the PCV passages in them also.
high pressure in cooling system jarekt Non-Generation Specific Questions 3 09-01-2007 06:39 PM
engine cleaning suprabahamut Off Topic Forum 1 07-10-2007 02:26 AM
Cold Air system? Black'88 Non-Generation Specific Questions 10 04-22-2006 02:40 AM
exhaust system kewlcoconut MKIII Supra 10 11-02-2005 07:46 PM
disarming factory antitheft system 89 supra cacarolturbo Non-Generation Specific Questions 2 05-22-2005 11:15 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
