Go Back   Toyota Supra Forums! Join the Supra forum! > Performance, Modification, and Maintenance Forums - for generation specific discussions > MKIII Supra > MKIII FAQ
Old 02-12-2005, 09:08 AM   #1
sprite059
sprite059 is on a distinguished road
Default Automatic to Manual Conversion
Hi I have just bought a N/A 87 Targa here in Aussie. I am going to convert it to manual, is there anywhere a detailed description of the process.
I was told that you only need the clutch pedal etc not the whole pedad assembly, is this true. My car is like new and has 210 ks on it.
sprite059 is offline   Reply With Quote
Old 02-12-2005, 09:27 AM   #2
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
manual conversion parts needed:
clutch pedal
brake pedal
clutch master cylinder
clutch slave cylinder
manual driveshaft
manual gearbox
manual bellhousing to fit your engine
clutch kit to suit whatever gearbox you have
clutch line to go between the master and slave cylinders
and jumper the pins on the auto trannie line so it bypasses the neutral start switch
(also by doing this it removes your reverse lights so you will need to wire these up separately)
reason you need the brake pedal also is because the auto brake pedal is wider than the manual and gets in the way of engaging the clutch pedal
good luck with your conversion and let us know how it turned out
Pics of my build.
Do a diagnostic first!
Old 02-13-2005, 03:09 AM   #3
300hpvision
300hpvision is on a distinguished road
everything suprra said i think is true
HELP ME FIND A STOCK SUPRA DAMN IT!!!
300hpvision is offline   Reply With Quote
Old 02-13-2005, 11:50 AM   #4
sprite059
thanks for that info, is the manual tailshaft longer or shorter than the auto one, I now all I have to do is to find all the bits.
Another question, is there any advantage of putting on headers/ extractors with a 2.5'' system or is it not worth the effort. I want to stay with my 7mge motor as is is very sweet but I want to get a bit more power, have ordered a K&N filter and plan to do a cold air duct
thanks for your advise.
Old 04-01-2005, 04:58 PM   #5
monkihead
SP58GT
monkihead's Avatar
monkihead is on a distinguished road
dont forget the driveshafts and prop shafts. i couldn't do mine with out them. so far as the headers go, you'll gain around 10hp or if your willing to spend money, turbonetics sells the performance mainfolt to turn the 7mge to 7mgte.
....all you need is a small taste of success and you will find it suits you....
monique- better off dead
monkihead is offline   Reply With Quote
Old 04-02-2005, 01:30 PM   #6
suprra_girl
7M POWAH! ;)
omg i forgot the driveshaft LOL
i blame it on me being blonde :P
Pics of my build.
Old 04-02-2005, 05:01 PM   #7
monkihead
SP58GT
monkihead's Avatar
lmao i got a lil blonde in me too...
Old 06-21-2005, 05:35 PM   #8
importnut
importnut is on a distinguished road
From the looks of it, the Auto is comletely mechanical? There is no Auto computer? Pardon my ignorance on the matter but I'm contemplating buying an MKIII and I'm finding nothing but autos, or beat 5spds. If it's completely mechanical, then the swap will be a piece of cake.
Alex
"What about the twinkie?"
importnut is offline   Reply With Quote
Old 06-30-2005, 02:23 AM   #9
jza80 Supra C-I TT
jza80 Supra C-I TT is on a distinguished road
should i just get an auto TT MKIV and just convert it or should i just spend some more time looking for one?
[img]http://rds.yahoo.com/S=96062883/K=supra+logo/v=2/SID=w/TID=I001_70/l=IVS/SIG=127fv51d7/EXP=1118546922/*-http%3A//www.supra.racingteam.kessler.com.pl/logo.jpg[/img]
<span style='color:green'>300 horsepower is 299 too much for any camaro</span>
MKIV POWER *cough* suprra _girl *cough cough*
jza80 Supra C-I TT is offline   Reply With Quote
Old 06-30-2005, 03:00 AM   #10
KingDiamond
KingDiamond is on a distinguished road
first you should get your license :lol: :P
KingDiamond is offline   Reply With Quote
HTML code is On
Automatic To Manual InColdBlood MKIV Supra 6 03-19-2007 07:52 PM
automatic to manual conversion aznwaterboy MKIII Supra 1 10-04-2006 02:29 AM
loc's automatic to manual conversion!!!! tone loc MKIII Supra 14 09-21-2006 04:19 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
